It's pretty much like that Alex. Because if you live at home you have a safety net below you invade something goes wrong. If you're out of home and you can't afford rent mortgage or bills your f**ked
thats not what i was saying.
it seems implied unless you dont live at home you dont work hard for money, you may say you work harder out of home cos you cant afford not to etc, and yes that would apply for lazy kents workin casually a day a week sleeping till lunch time but i work full time have since hte day i left school, yeh i live at home but in 6 years ive had a bout 4 weeks worth of holidays and i save my cash like no tomorrow just cos i live under my parents roof doesnt mean i dont work hard
my dick feels better in a nice warm vagina. it doesn't mean I walk around all day with a woman hanging off my hips.
would be good though
Just found my leather gear and hand brake boots if anyone needs to replace theirs...brand new, never been installed
how much? my handbrake boot is worn out. dont really need the gearstick one :blink:
and that's not what -I- was saying. If u reread I said 'work hard for everything they have'. For example, my parents were never well off, they worked really hard to provide what was needed for their three children and as such I'm used to not being spoiled by my parents spending huge amounts of money on me or my sisters like some peoples parents do. I'm used to having to work for everything I want and work hard or it doesn't happen. My car is under finance because even working full time I paid board etc... It was the easiest way to do it. Now we have rent and bills as well on top. If I don't work hard the car is taken away. Could be kicked out for not being able to make rent. Etc. Life is so much easier with ur parents providing everything you need. Far less stressful.
I'm not saying I dont think you work hard. I'm just saying the conseqences are a lot worse without mum and dad there to bail u out if u need it.
how much dezz?
was gonna say i dont wanna seperate but if you niggas wanna share then go for your lives...although does mean I have to post to 2 mother f**kers instead of 1...
asking $80, but for you 2 $35 a piece + postage?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
