7 Eleven $1 day is back!!!! :D
Tomorrow, Thursday 16 September, is 7-Eleven $1 Day!
Mother 300ml, Nestle Medium bars, Twisties, Burger Rings & Cheetos 90g, Goulburn Valley flavour milk, Four'N Twenty Snack Pies, munch Cheese & Bacon rolls, Nestle Drumstick ice creams, Golden Circle lOL! juice and Bercocca Twist 'n' Go.
....So raiding my nearest 7-Eleven tomorrow Wooo! ;)
No one gets fired from my work. Unless you steal there is nothing they can do lol
LOL!!! coz no one decent wants to work there and they always desperate for people...lol...bloody woolies...
Made me LOL
:P
nah man that car is phag as.
seriously though
nissan wheel thread same as toyota.. anyone? as in can you use nissan nuts on toyota studs.
depends on toyota. celica no. poopra yes. hachirusto yes. estima/tarago no.
6th day of work in a row... yayyyyyyyyyyyyyyyyyyyy
and i got to work tomorrow as well.. 1 hour down 8 more to go fml.
i'm about ready to walk out of here right now
less talk, more quit, or stfu and suck it up princess.
AWW..suck it up princess...i do 7 days 8 hr days..now less surfin net...more working..chop chop.. :P
lol, only reason why im still here is to save some money for when i DO quit and looking for a new job so i'm not doll / bogan spec.
so err shan you need a networker? :P
and surfing the net is the only thing keeping me sane from stupid ass customers
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
