7 Eleven $1 day is back!!!! :D
Tomorrow, Thursday 16 September, is 7-Eleven $1 Day!
Mother 300ml, Nestle Medium bars, Twisties, Burger Rings & Cheetos 90g, Goulburn Valley flavour milk, Four'N Twenty Snack Pies, munch Cheese & Bacon rolls, Nestle Drumstick ice creams, Golden Circle lOL! juice and Bercocca Twist 'n' Go.
....So raiding my nearest 7-Eleven tomorrow Wooo! ;)
No one gets fired from my work. Unless you steal there is nothing they can do lol
LOL!!! coz no one decent wants to work there and they always desperate for people...lol...bloody woolies...
Made me LOL
:P
nah man that car is phag as.
seriously though
nissan wheel thread same as toyota.. anyone? as in can you use nissan nuts on toyota studs.
depends on toyota. celica no. poopra yes. hachirusto yes. estima/tarago no.
6th day of work in a row... yayyyyyyyyyyyyyyyyyyyy
and i got to work tomorrow as well.. 1 hour down 8 more to go fml.
i'm about ready to walk out of here right now
less talk, more quit, or stfu and suck it up princess.
AWW..suck it up princess...i do 7 days 8 hr days..now less surfin net...more working..chop chop.. :P
lol, only reason why im still here is to save some money for when i DO quit and looking for a new job so i'm not doll / bogan spec.
so err shan you need a networker? :P
and surfing the net is the only thing keeping me sane from stupid ass customers
