lol at the skinny jeans the fag is wearing
haha skinny jeans are 100% fag... 0 to douchebag in 0.1 seconds
oks
350z to is250?
jah...
AWW..suck it up princess...i do 7 days 8 hr days..now less surfin net...more working..chop chop.. :P
that's 56 hours a week.... at the moment i do that every week as an absolute minimum, and over christmas time i'll be adding another 20 to that
lol i start work sometime between 8:30 and 9:30 and finish around 6:30, although I usually leave work at about 8ish. Plus I've come in on the weekend to get shit done for the last two months.
mind you if i stopped being on SAU or ZT and reading blogs etc I'll probably cut an hour n a bit out of my workday.
HR sent me a quiet email askin me to take annual leave cos I've got like 5 weeks accrued, which I forwarded to the CEO with "hahaha I'm outta here". Got an email back going "not till the end of the year, we need you."
Fuckin end of year bonus better be 5 digits.
if i did that i wouldnt have a work day hahaha..
<3 my job..sometimes.
same on annual leave had 15 days off in 4 years.. they owe me a fair bit :P
I've got 9 weeks accrued - but there's no way I'll be able to take any til after we release later in the year
Our company policy is that we can't have longer than 4 weeks annual leave. If we do we gotta take it in chunks of 4 weeks... not like an epic break to go around the world or someshit.
Ours is that we should have no more than 6 I think except with manager approval - I have manager indifference
I have this too, but we have an HR department full of pregnant women that have massive mood swings.
fact that it's a S30 fastback makes it instantly better than any other car in this thread.
20mm spacers ordered. No more tucked in rears :P
great, now you're gonna be mexican. what happened to 10mm to 15mm?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
