thought id do this modifying thing properly and instead of just getting power i decided to make my suspension better, i just bought a bunch of nolathane bushes, nearly there whole catalogue for the gtr. cant wait to see what it feels like when its all fitted :)
lol slow at replying
Ice cream on lygon, then Eureka Skydeck. Guaranteed date win.
Yeah date win
bahahaha nah man we just seeing where things are going.. shes a smart girl so don't want to screw things up :)
Sounds like a good idea actually, maybe save it for a more warm night
nah no need for a warm night.... i always get ice-cream with missus down lygon the gas heaters they have along there keep you warm while you eat
This is true :)
Hurt much?
A little bit.. 1st session for the outline took 2 hours which hurt a fair bit especially on my ribs then the other 3 sessions were only an hour. Last session was the top part which I thought was gonna hurt like hell again but I couldn't feel it.. I was more relaxed I think cause I knew it was gonna be finished :laugh:
shan how would 17x9x+20 go on an R32 taxi?
thankss, lots of love, xoxo.
(change my name back kunt :) )
lol that would need some serious flaring and camber to get right. Will be scrub central on the front.
17x9 +30 is the ideal setup for r32 gtst's.
thats what nisskid recomended with stock guards and low.. any chance sedans are different?
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
