7.0 +40 isn't that bad on a cube actually. it's just offset out like a mofo, so no concave/dish.
16" is a bit weaksauce though. 17" minimum to look baller.
Unfortunately they start getting too wide in 17's for the design I like. 16's are a bit easier and more available.
You're right, 7.0" ~ +35 is about the limit before the inner guards need rolling.
This is what 7.0" wide, +15 offset looks like. Get your mexican hats ready:
nice billy,
you been to the top gear test track?
come get me this saturday my car is running again
you still at supercheap? if so i need fire extinguisher and those socks for fluid bottles. thanks :P
Yer had a look the other night too much rubbish on the strip!
If I do go anywhere I'll let you know :P
I need to buy an extinguisher too, just waiting for our usual buy one get one free sale, let you know :P
yeh thanks need it soon but cos of winton :P
yeh gotta go a bit off road to get there apparently.. i havent been only get car started the other day LOL i better take it out tonight though keep the battery charged :P
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
