I'd say F1 would require the most skill.
Take all the skills needed to drive, then reduce the reaction time available by tenfold.
True that, but the F1 car are now slowly going back to driver skill. Few years ago it was all electorincally assisted? mostly car not driver.
More likely to die in rally. Also much more interesting to watch rally. See any pikes peak hillclimb vid and tell me you aren't impressed. Skill level is probably on a par, just in different areas.
when was the last time you saw an F1 car with a rollcage?
F1 car = nuts hangin so low that they're literally 5cm off the ground.
I got my rally day in november! Driving a Evo 7 round a rally track. Hope they got insurance! hahaha
Is that the one out near ballarat? My mate went to that one and they gave him a Magna VRX "Evo". He asked for a refund and they refused.
Say whaa, nuh this one is in werribee
And says your choice or a Lancer Evolution 7 or a Subaru WRX
haha magna vrx as an evo
nice work
i went in an evo 7 around debortoli with scott pedder
that was pretty sweet, fair driving he can do
brake and accelerate at the same time
When was the last time you saw a rally car with a CF saftey monocoque shell?
Rally= nuts so big they be sideways at 80-100k's an hr 20cm from a massive drop off a mountain. :)
Dunno about last time, but I can tell you the first time... 1987. Lancia entered 2 CF shelled rally cars.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
