so you're pulling the lever next to the seat and it's not doing anything?
where the boot clicks in there's a metal lever thing that pops up or down, reverse that and you're set
seriously if you can't figure that out.. you're going to enjoy owning a Skyline. /sarcasm
lol is that called a valet switch? its just under the latch on the inside f the boot, should be a lever that you flick to the left to disable and right to enable, or the other way round. I never saw the point of it. cos seriously, if you're driving a skyline, your budget/social status doesn't allow for places that require you to hand over keys to a valet.
Indian can't drive, full stop, take note. Don't ever give your car to Funky or basti lol
i always drive like I stole it, even if I've paid for it completely. its genetic.
i never ask to drive people's cars, and i never let anyone drive mine. not worth the hassle.
also, neither me nor niggaroj are indian. bez is.
the number of people that have asked if they can drive my car at the moment is insane.
do these lebs not understand?
why do they keep insisting on massive GT wings, neons and chromies.. WHY!?
yes and no really. English by birth :P makes a bit of difference lol
I can drive i think...and i am Indian...prob the only rare couple ones who can drive...hate the fobs driving skills...they drive like they are back in India.....
we're lankan mate. but yes dont give us your cars if you want em back :down:
TYPICAL!!!! we all are the same buch...not much difference.... :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
