so you're pulling the lever next to the seat and it's not doing anything?
where the boot clicks in there's a metal lever thing that pops up or down, reverse that and you're set
seriously if you can't figure that out.. you're going to enjoy owning a Skyline. /sarcasm
lol is that called a valet switch? its just under the latch on the inside f the boot, should be a lever that you flick to the left to disable and right to enable, or the other way round. I never saw the point of it. cos seriously, if you're driving a skyline, your budget/social status doesn't allow for places that require you to hand over keys to a valet.
Indian can't drive, full stop, take note. Don't ever give your car to Funky or basti lol
i always drive like I stole it, even if I've paid for it completely. its genetic.
i never ask to drive people's cars, and i never let anyone drive mine. not worth the hassle.
also, neither me nor niggaroj are indian. bez is.
the number of people that have asked if they can drive my car at the moment is insane.
do these lebs not understand?
why do they keep insisting on massive GT wings, neons and chromies.. WHY!?
yes and no really. English by birth :P makes a bit of difference lol
I can drive i think...and i am Indian...prob the only rare couple ones who can drive...hate the fobs driving skills...they drive like they are back in India.....
we're lankan mate. but yes dont give us your cars if you want em back :down:
TYPICAL!!!! we all are the same buch...not much difference.... :P
