ke's gone up in value brah
gotta get ya self outta dandenong and visits places where people actually pay for cars.
as in not steal them.
fuck off. I'll steal my cars till the day I get caught. nevarrrr!
KE's appreciate in value by 50% when they have a full tank of petrol.
yeh, but car is sold as having NOTHING to do... just get in and sliiiide :(
what? fuck. nooo really? omg. lemme get in on this...
FOR SALE:
1980 honda civic with maccas trays on rear wheels
"NOTHING to do... just get in and sliiiide"
4k ONO.
that's all well and good, but maccas trays only last a few hundred meters at best, so your ad would have to read:
FOR SALE:
1980 honda civic with lifetime supply of maccas tray's for rear wheels
anyway... i said i'm starting @ 4k... gotta start above what you realistically expect to get
^^ From memory, you picked the KE70 for a good price.
You'd probably make some cash back too!
4K, that's AE86 money brooo
ngas only go to KE70's cos they can't afford AE86's. no pimply faced maccas wage earner's gonna be able to afford your car.
lol I'm just takin the piss. I bought my AE86 for $600 (in running condition) and sold it for $2000 with no engine, no interior etc... so I know exactly how retarded maccas employees are these days.
LOL!
I saw a matt black KE70, previous owner bought it for $400 and sold it for $2000, stock.
If it is for your R32, it should have been done during compliance...
15 year import bro (well 15 years, 5 years ago). You don't have to do shit, just loosen the cap before you chuck it on the ship to degas.
Ah yeah LOL!
So easy to bring in R32's now.
Mine was bought in under the 15 year rule.
Mohsen, you mechanic should be able to re gas it.
shan, took your advice and tried yahoo japan...and googled it...and
i even looked on nissan silvia hoping those bastards would have a lonesome 18x9.5 super advan gen 2 for me.
but alas i have no luck on any website i try.
guess im screwed. stupid broken wheel.
on a related note anyone know anyone with one super advan gen 2 18x9.5? other 3 on my car are fine. *is broke as a nga with no money for new rims* :D
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
