But mine's newer and more reliable. And an R34, which makes it infinitely more awesome.
In other news, closest I could book my Cube in for it's rego inspection is next Thursday...
Vicroads ftmfl :)
LOL!
Yeah, your R34 is one of the cleanest I have seen.
doubt anyone would pay 15k for your car tho juliette :) skylines arent worth shit these days, can get clean r34 gtt coupes for 12-13k
It's not an unreasonable asking price, it's right at the low end of the market. I'm aware of the cheaper ones but seeing as though most are sitting around the $18-20K I see no reason to lower it.
I put my car up for sale and listed all the issues.. including bent chassis :) Straight away I got heaps of interest!! People will do anything for a GEN3 lol.
Gonna be weird driving a GEN2 ;) Only 162kw.
There's 10k worth of parts on your car? ;)
$4000+ stereo - GPS/DVD, 2 amps, splits, sub, Optima Yellowtop etc.
$2000+ cream leather Recaros
~$3000 wheels tyres (even though I paid more :) fail)
94+ tails (around $500+ for new ones) - Will put my old 1990 ones back on
And a bunch more...
See what I mean? :)
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
