can you guys come up with some clever plates for the v-dub?
has to start with a V + two letters + three numbers.
So far I've got:
V DU888
V DU885
V DU813
V GO 101
V ZE 070
V NO 600
V MK 004 (it's a MK4 golf... but model names in plates are a pet hate of mine so no)
I have the sudden urge to buy an R34 now. Mainly because some of them are getting as cheap as MR2s.
Like so: http://www.carsales.com.au/all-cars/privat....aspx?R=8919840
Edited by jezza boii
meh, i just want euro plates cos:
1) I get free plates as a birthday present from my mates
2) it's the only plate that fills out the numberplate bracket. regular VIC plates look like ass on euro plate brackets.
given your previous buying decisions, I thought you'd go more for a Soarer or something lol
Nah, I like cars that handle :)
p.s. 300ZX doesn't count. I bought that coz I like the lines.
Should have bought that in the 1st place!
i see. LAWL.
Cars that don't handle that you've owned:
Poverty spec MR2
300ZX
Poopra
MR2 with awesome bent chassis for superior handling
Cars that handle well that you've owned:
The end.
possibly the funniest thing that has ever been written...
if that joke was translated into german it could have won the war!
aren't the custom euro plates bullshit expensive, whereas if you just get the next available combination they are much cheaper?
EDIT:
Standard/Next Available
$495*
Personalised
$695*
jeebus. your mates must like you.
yeah, one of my mates works at vicroads and him and a bunch of the lads got together and chipped in for a full custom plate. apparently they thought cos I was into cars I'd like a custom plate, rather than say, I dunno, the cash so I can buy adjustable arms or camber plates or some shit.
no way in hell I'd shell out my own money for a custom plate unless there was a scam involved.
we usually chip in about $50 to $100 each for a birthday present. Adds up when you put 5 or 6 people together.
shan. get STOLEN
people would believe it when they see an immaculate blue tampon being driven by an indian lookin dude
A mountain goat that fatally gored a hiker, then stood over the man and stared at people trying to help, had shown aggressive behaviour in the past,
:woot::)
It wouldn't move. It stared us down."
bahahahahha shame they killed the thing. wulda been a f**king great guard animal
Edited by Mohsen
shan. get STOLEN
were you born fuckin retarded or did the doc just decide to dropkick you at birth? which part of STOLEN fits "V, then two letters, then 3 numbers"?
fuck. you know what, don't stress about not taking your sister to the school ball this year, with your fuckin genius I'm sure you'll get another 4 or 5 proms out of the education system.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
