as a previous iphone user, i can recomend the htc desire, its a good phone, or wait till the htc desire hd comes out, galaxy looks just like an iphone imo, and the case is tacky and plasticy
oh k...heard the galaxy is much better than the HTC and a bit of a better option then the iphone 4....from these three options i heard and believe, the galaxy is a better choice...but is there anyother options around?
Aww yea true Hamish. Pats car is a daily driven track car! I forgot LOL
haha
im on 17's still, just went wider and lower offset
looks good though, and i can run 235/45 17s so tyres are cheap as anything lol
guys i am due for a new phone....whats good to get? I really want to avoid iphone but if its really the best in the market ill shall...what other options do i have? any one got the new samsung galaxy? any comments on it? cheers...
galaxy is win, heaps better than HTC or iphone
I'm trying to watch a jdm option dvd on my laptop, but its telling me I have to change region codes and I can only change a few times before it locks it.
Does anyone know of any good free region-free programs I can download to prevent this?
read
http://forums.whirlpool.net.au/forum-replies.cfm?t=1489341
(make sure its standard view and not archived view so u can see the poll)
Kk I'll try from the top of my head
Garrett 3076 .82 rear
Ported manifold
Z32 afm
Nismo 740cc injectors
Bosch 040 pump
Blitz dual solenoid sbc
3 inch straight through exhaust
Powerfc
Greddy cam gear
Think that's the main part of it
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
