gentlementlemen...
just gave a counter offer on:
http://www.j-spec.com.au/featured/fairlady-z-11157.html
FUCK YEAH
Seller came back with a offer that was good enough to accept. just putting some last minute vice clamps on his nuts to squeeze a better price.
:D
FUCK YEAH!
L28 board to 3100cc
Do it!
He said it was a kakimoto 3.1L. not sure if it's a genuine one or a replica using LD28 crank, honda pistons etc.
said I'd buy pending on the mechanic inspection, gotta get the guy out there into hickville country japan. will know then.
apparently makes 215rwkw :D not bad for an old clunker.
lol i completely forgot I had inquired about this car, until it got brought up in the "300zx vs GTR... engine out fun" thread. Couple of phonecalls later and I jizzed my pants.
wow. remember when you gave me shit for almost buying a c110. yeah. f**k you old man!
lol that's cos I'm not gonna be restoring or modding anything. buy, import, tune, drive. the end.
If it's genuine 3.1 kit, you're essentially sitting on gold mine...
I've owned one before in the C10. Didn't realise it was a gen until I opened the bonnet (this was back in the day when we bought shit sight unseen). Hence the $5000 profit once it got here.
no sell? good
looks like charles got to that Ferrari
im still kicking myself for not buying adz's c110... or that restored road/track 260z 2+2 with the l28 etc etc stripped, half cage, semis and watanabe copies for 4.5k
you should own a regular car before you take on the headaches of a classic.
put it this way, this car's gonna be driven hard once a week. if it breaks it'll go into a workshop while I drive a daily. you, on the other hand don't have that luxury.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
