the only people who'd be envious of your R32 are 4 year olds on tricycles cos you have 1 more wheel than them. However even they don't need their mum to supervise em while driving, so I'm sure they too wouldn't be envious of your shit.
i actually agree.. its an old r32 taxi haha
whats to envy
i was thinking of buying a front pipe for the gtr but im not sure now because the stock one doesnt look that much different to the aftermarket ones, plus they say that the dump pipes are good in the r34gtr so i dont have to worry about that either. maybe i should just get an aftermarket ecu instead.
R34 GTR Dump Pipes will be fine, but I'd change the front pipes (get a full / turbo back exhaust).
I did on my R32 GTR and the exhaust flow is so much better.
You could do ECU, but if you don't have any extensive mods, it's not much point as the stock ECU can handle what it is doing.
ive already got the catback and got a new cat ready to be put in. but after looking at pics of a stock r34 gtr front pipe and aftermarket ones i dont see much difference and the sizing doesnt look small either so i just dont see much of a gain for the price of these things. so i thought id just put it towards an ecu instead and help with the very rich tune it has. but if anyone knows better with r34gtr's and there front pipes and what i should do id like to hear from them :P
get a blow of valve that goes sututututu
it. gets. bitches
you have no clue
im not after bitches im looking for broad minded persons.
edit: ok it doesnt let me say s-l-u-t-s
sluts
uras kit acquired.
thought you were selling?
go to any club on a friday or saturday night
you have no clue
being sarcastic mannn
sluts
ahahah i know the secret!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
