Turbo - from $1300-1700 brand new
Ecu - from $800-1200 used PFC
Injectors - $800-1200 depending on brand. New
Fuel pump - $200
Custom dump pipe - ~200
Wastegate - 500-700 new
Labour - depends who
Dunno if I'm missing anything but they would be the essentials.
1300-1700 won't get you a new Garrett with a IW. Also not included in your price is oil and water lines. Extended studs. Spacers, Garrett dump pipe.
1700 will get you a external wasted turbo. Gt30 or 35
Most people with street setup cars dun want a big obvious external wastegate there lol
why singapore/thailand muznick?
im going europe next year should be good
was my sister-in-laws idea to go
planning on going US when the dollar is apperently going to get even better
coz he likes the asian bitches
damn straight
My tuner seems completely comfortable with tuning the boost up to 14psi on my beloved r33 provided its being managed by a good electronic boost controller. Reckons he's done tonnes of RB25s with 14 odd psi and acknowledges that while it's up on the limits of what the turbo can achieve, it will be relatively safe. I'm a little hesitant.
I added external gate price so why would the price I said be for a IW lol
I estimated a price too, I can get a 3582 for 1400 so I just added a few hundred more for retail.
Does that mean your running IW? When the time comes I'm definitely running external, your only worried because your an eastie lol
on a bigger turbo better to run an external gate as itll control boost better
IW can spike on high boost applications
plus external can be plumbed back and still be fairly quite on the street, and be hidden in the engine bay..... somewhat lol
LOL
Have you measured the diametre of the pipes?
Even if you can't get to the inpipe, measure the outpipe diametre.
"Very rich tune"..?
You have a stock ECU / Re-tune..?
Turbo cars run alittle more rich, which is normal.
I guess if you do go ahead with the ECU, it can benefit in terms of refinement of your Air / Fuel system = Smoother running car = Better performance.
:blink:
ive got that tuned nismo ecu in my car atm. ive got the money for an ecu right now so i was thinking of getting it or maybe ill just buy a blitz frontpipe.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
