Turbo - from $1300-1700 brand new
Ecu - from $800-1200 used PFC
Injectors - $800-1200 depending on brand. New
Fuel pump - $200
Custom dump pipe - ~200
Wastegate - 500-700 new
Labour - depends who
Dunno if I'm missing anything but they would be the essentials.
1300-1700 won't get you a new Garrett with a IW. Also not included in your price is oil and water lines. Extended studs. Spacers, Garrett dump pipe.
1700 will get you a external wasted turbo. Gt30 or 35
Most people with street setup cars dun want a big obvious external wastegate there lol
why singapore/thailand muznick?
im going europe next year should be good
was my sister-in-laws idea to go
planning on going US when the dollar is apperently going to get even better
coz he likes the asian bitches
damn straight
My tuner seems completely comfortable with tuning the boost up to 14psi on my beloved r33 provided its being managed by a good electronic boost controller. Reckons he's done tonnes of RB25s with 14 odd psi and acknowledges that while it's up on the limits of what the turbo can achieve, it will be relatively safe. I'm a little hesitant.
I added external gate price so why would the price I said be for a IW lol
I estimated a price too, I can get a 3582 for 1400 so I just added a few hundred more for retail.
Does that mean your running IW? When the time comes I'm definitely running external, your only worried because your an eastie lol
on a bigger turbo better to run an external gate as itll control boost better
IW can spike on high boost applications
plus external can be plumbed back and still be fairly quite on the street, and be hidden in the engine bay..... somewhat lol
LOL
Have you measured the diametre of the pipes?
Even if you can't get to the inpipe, measure the outpipe diametre.
"Very rich tune"..?
You have a stock ECU / Re-tune..?
Turbo cars run alittle more rich, which is normal.
I guess if you do go ahead with the ECU, it can benefit in terms of refinement of your Air / Fuel system = Smoother running car = Better performance.
:blink:
ive got that tuned nismo ecu in my car atm. ive got the money for an ecu right now so i was thinking of getting it or maybe ill just buy a blitz frontpipe.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
