Got my car back yesterday. Sooo f**kin loud!!! Full 3" exhaust, 3" hiflow cat, twin pipes, no mufflers or resonators just pure rb roar :verymad: makes me smile everytime I start it.
On another note. Added suspension bits now the car pulls left and right and feels all over the place. Apparently a wheel alignment will fix all of this, find out soon....
mine was all out of whack at the rear before alignment too use to like get pushed in different directions,
your exhaust is farkn sex.
do want.
do want.
pixofsaidexhaustorban
Your undergraduate/other graduate preferences are:
Code Course
1. 12261 Paramedicine (Australian Catholic University, Melbourne, F/T, P/T) (Type: CSP)
2. 43031 Paramedic (Victoria University, St Albans, F/T) (Type: CSP)
WISH ME LUCK lol
Code Course
WISH ME LUCK lol
goodluck
RMIT just sent me a letter for product design... they want me to write out a paper as to why i want to become a designer( to make a living?) and then an interview
lol...true that....just say i really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really love to become ....
that should be enough....gay applications...hate them..lol..
One of my old tutors from uni was a paramedic. Some of the shit they have to do... f**k that.
One of the jobs he was called to: Picking up pieces of a person after they been hit by a train
someone's gotta do it...
it's more about the positives of helping that the negatives of failed train surfing :P
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
