A few, at funerals and shit :P Would be even easier if I didn't know the person. I'm just not really phased by death etc. like normal people are. It's just a fact of life in my eyes.
In other news... FUUUUUUUU my bodykit got damaged in storage. Better hope fiberglassing can fix that shit.
im a stonemason and yet to touch a dead body so far, you got some problems dude :D
although death doesnt phase me either, just puts life into perspective more
What year? I applied for their architecture course and had to do that wierd test thingy in Swanston St in late 2001. Didn't get in, so ever since, I've been a sparky :P
In a way I kind of want to do a bit of tertiary study for some better coinage, but no idea what, and most things probably wouldn't pay as well as what I am doing now. I'll possibly just teach myself some PLC programming, as there is some big bucks to be had in that.
2006 for me. I never showed up for the interview lol. Aaah well, one day i'll figure out what I want to do with my life lol.
how many dead bodies have you touched?
icwatyoudidthere
LOL
ignitor arrived, put it in. some improvement overall but still dead in cylinder 1
gonna get my loom checked out tomorrow, if its fine. ill move onto injectors
Nice one, I had a Trust DD back when I had a skyline
hmm thats quite sexy. would yo get away with driving that on the street?
and jez im just asking because seeing someone laid out in a casket barely counts, cos they are cleaned and perfumed and have make up etc on to make em look nice for the family. hamish is gonna have to put up with worse than that. good on ya hamish, there can never be too many paramedics. is mez for or against you getting into the health industry? curious to find out where she stands lol
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
