hmm thats quite sexy. would yo get away with driving that on the street?
I did, but I had 4 doors, the extra doors seemed to make it invisible. It also has big silencers shoved up the end that you can remove for more loud.
please explain
as in it was too short? or the fact it had 4 doors made it seem like a family car
please explain
nah, fit of exhaust was perfect, flush with the bumper. Just never got pulled over.
ahk cool
just got my coil loom looked at. turns out the connectors are pushed in :)
that could be my problem
lol @ you crazy boat owners
and if you go twin pipes you gotta have em tapering out larger at the ends :)
a mate had the same as these on a Cefiro, then on a HR-31, they give a bit of a deeper note than just a pipe, sounds porn
Edited by bozodos
I prefer R32s.. but not 4 doors :) Sorry mohsen. Nick's was an exception.
Btw, on the topic of exhausts, I've got a 3" system coming :rofl2: PP Departure. Will whack it on after my gearbox is in.
ahk cool
just got my coil loom looked at. turns out the connectors are pushed in :rofl2:
4 doors are longer so a coupe exhaust will sit flush/just behind the rear bar
Btw, on the topic of exhausts, I've got a 3" system coming :D PP Departure. Will whack it on after my gearbox is in.
win lol.... Moshen shouldve just bought it when i was selling and wouldnt have all the headaches he has now...... and a better car lol
or a licence. or a functioning car.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
