What kind of stuff do CJ pearce do?
I was subbying to them for the past two weeks. They have the Port of Melbourne contract, so they do anything and everything associated with the shipyards around the city, but they also do a lot of industrial based wiring (mostly power, minimal control). I think they do a bit of HV as well, so there is some variety there.
Lol nope nothing at all....
Although I do know enough to know that stock suspension sucks balls, that's probably why you just sold yours...
Can u explain why you think own suspension is bad for straight line drags?
The only reason I sold mine is because I got real serious about wanting to go fast and spent thousands on custom drag suspension.
Have a read about what type of suspension makes a car go fast straight line and what makes it go fast around corners. Then maybe you'll stop preaching nonsense.
Sorry i didnt realise the car was going to be driven in a straight line only....
At what point did anyone say it was going to be a drag car and did I at all say stock suspension was bad for straight line drags?
Nor did I preach anything, I know exactly what type of suspension is required for each set up.
Edited by blags
