What kind of stuff do CJ pearce do?
I was subbying to them for the past two weeks. They have the Port of Melbourne contract, so they do anything and everything associated with the shipyards around the city, but they also do a lot of industrial based wiring (mostly power, minimal control). I think they do a bit of HV as well, so there is some variety there.
Lol nope nothing at all....
Although I do know enough to know that stock suspension sucks balls, that's probably why you just sold yours...
Can u explain why you think own suspension is bad for straight line drags?
The only reason I sold mine is because I got real serious about wanting to go fast and spent thousands on custom drag suspension.
Have a read about what type of suspension makes a car go fast straight line and what makes it go fast around corners. Then maybe you'll stop preaching nonsense.
Sorry i didnt realise the car was going to be driven in a straight line only....
At what point did anyone say it was going to be a drag car and did I at all say stock suspension was bad for straight line drags?
Nor did I preach anything, I know exactly what type of suspension is required for each set up.
Edited by blags
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
