if you leave it at the height it is, it shouldn't matter if it's mexican... cos it doesn't look that bad. you'd only wanna camber if you're gonna drop it and tuck it... which I highly doubt you're gonna. so don't bother.
it doesn't stick out that far does it?
Damn straight!! Otherwise kris would have coilovers and a lowered car by now
and no sydney spec failside knockoff kit
or transexual tangerine paintjob :D
But mad retspec for not caring about our opinions, same reason why I'm modding a golf. I couldn't give a flying fuck what you muppets think about it.
They're sticking out a few mm still. I really thought the guard pull would have fixed it but apparently MR2 guards don't give much. That's why I thought a little bit of camber might make it look slightly nicer.
I wouldn't mind dropping the front a bit more.. I think I could get away with it. Whereas the back the sideskirt is almost touching the ground.
Maybe 1" more at front and 0.5" at the back. Or would that look retarded if the car was sloping down at the front? :D My ZX had SSLs in front and standard springs in the rear. Actually looked acceptable.
im running mexican on front pretty badly..... cars not low enough to need to tuck em, and being 17s you dont notice it as much as an 18 in the same size/offset
plus with a 235/45 on a 9.5 the tyre stretches in a touch so its even less noticeable
well not certain but i'd think it will be similar to most areas ie. pretty sh*t at peak times.
unless they have upgraded the exchange but i doubt it.. most ppl go for wireless
that shit's pretty steep for any kind of decent download limit isn't it?
alex. that's the same grille I got as well. Probably end up with same colour too, maybe a shade darker. but I'll be rockin wider wheels and more low :D
Oh and real xenons, rather than those knockoff HID's he's sporting.
Oh god. I've become a Dub Snob.
haha my customs agent just asked me to come to their work drinks.
she's not bad lookin either... :D
http://profile.ak.fbcdn.net/hprofile-ak-sn...1_1523313_n.jpg
bitta chubs on the arms, but I can overlook it for the smile.
dhtrhsrhsh
yo, r-spec u posted this a while ago the reason i bring it up i would like to no where i can order these nismo vents shown here in black
any chance u would know where to find them i have searched for them no luck or if anyone else can help
cheers.
just gave a guy from work a ride home and he was amazed to the music i listened to lol. just cause i drive a skyline why do they think i listen to that dance or trance doof doof music stuff for lol.
ok wtf, turns out she was married in october last year.
bit more stalking...
http://c1.ac-images.myspacecdn.com/images0...49d64542d24.jpg
this is not relevant to my interests.
So any phone geeks (Shan, I'm looking at you) able to help me?
Been offered a HTC Desire HD to replace my iPhone 3G... yay or nay? I'm a bit over the iPhone, so wouldn't mind trying an Android or W7 phone, but yeah...need some more smarterer advice.
HTC Desire HD? Fuck yes. Only phone I'd choose over an iPhone 4, not so much a jailbroken iPhone 4 tho.
Don't expect the same battery life as an iPhone tho, expect to have to charge it by the end of the day every day. Other than that, it's awesome.
Might wanna hold off a month for the Google Nexus S (built by samsung) or the Sony X10. Nexus S is like the new model Google phone (so updates n shit aren't provider dependent like with HTC, Samsung etc), Sony X10 is like an awesome piece of hardware running android... probably the best "phone" cos Samsung (korea) and HTC (china) aren't really up there with the build quality of Sony (japan/norway).
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
