russia's not all covered in snow and def not all through the year you luddite.
do not correct me while im trying to make a point. kthx
Bade hey rimon. Fkn Arabs. Qatar sucks. Seriously, it's like a wannabe Saudi. And their Arabic is bastardized to the point where I can't understand them.
Btw, girl didn't really die. I just yelled at her for doing something unfavorable.
yea we shoulda got 2022 man sif that cartoon kangaroo thing wasnt impressive enough... bet that julia gillard f**ked it up for us
hey muzNick whats the 6.5 TM like? is there much difference mechanically to the 7s or? drove next to a blue 1 today they look tuff as, looks nothin like normal lancer
TME are pretty good, mechanically they dont have the active rear diff like the 7/8/9 but that doesnt really matter
light than the 7s and heaps faster..... different seats and steering wheel than the evo 6, no radio, titanium blades on turbine.... thats all i can think of atm
no radio? f**k that lol
otherwise mmm interesting
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
