Nope... Scared to get into a crash with some douche with a single pegger commodore trig to impres me.... and/or losing my license
Yea there are a few of them out there... well lots, but depends on what time you go. If your out at 2am and after thats when the serious cars come out and the little p platers leave. We had a proper DRAG setup xr6 turbo with us once. runs 9 second quarters. I just sat back and watched. lol
Where are all the po-lice on this hwy you speak of?
Modern psychology indicates that people who unnecessarily criticise others are often deeply unhappy. Such individuals may have low self esteem or perhaps may even be depressed. When people are sad or insecure, often the world becomes a very dark place and they see their enemy everywhere. It is at this time they start to 'act out'.Putting down others can also be considered a form of 'projection', in that the aggressor projects onto others what they really feel about themselves. When an insecure person calls someone a 'gimp', really this is a direct reflection of how this person feels about themselves. Accordingly, this person will insist on insulting the other first as a means of escaping these negative, insecure feelings. The more unkind they are, the more distance the aggressor then creates between the victim, resulting in the need to work harder to gain the victim's attention in future online situations. Much like the attention-seeking behaviour of a naughty little child, the aggressor will then try to re-establish this connection via inappropriate means, as highlighted in the above forum post.
thats gold jerry! gold!
why do you always have to be so negative?
coz that's how I roll.
also esp to sam cos he went out and bought a car everyone told him not to, and now have to watch and listen to slowly go about everything arse first. lets get real, it's only a matter of time before he gets dicked, then blacklisted, then targetted, and he comes on here and has a cry cos the cops are camping outside his house waiting to suspend his license and make him go through an EPA.
once he gets something in his head he never lets it go, he loves an R32, that's fine. why not buy a N/A? nah, he sees all the guys rollin in turbos like Kris and Hamish goin on about 11ty billion killabees at the wheels and wants to be part of that. these guys aren't on their P's and are a lot older than him. it's just plain thinking with the peen instead of the brain.
if we all sat around givin each other reacharounds about how awesome each others cars are, and JO each other silly about the faggotry you guys indulge in when it comes to modifications, then you'll end up with Kris never knowing that his car looks like a skittle coloured hovercraft, jeremy with sunken battleship chromies for wheels, niggaroj with enough clearance to hide Assange and Bin Laden under his wheel arches, mohsen with a dose pipe, etc.
no. I'm sorry if some of you delicate little flowers can't take creative criticism with a pinch of salt and not get butthurt over it. if you don't like it you can get the fuck out.
yup, totally got me figured out. so insecure. i cry myself to sleep everynight cos I'm so jelly about you guise.
  • Like 2
  • Nope 1
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
