Nope... Scared to get into a crash with some douche with a single pegger commodore trig to impres me.... and/or losing my license
Yea there are a few of them out there... well lots, but depends on what time you go. If your out at 2am and after thats when the serious cars come out and the little p platers leave. We had a proper DRAG setup xr6 turbo with us once. runs 9 second quarters. I just sat back and watched. lol
Where are all the po-lice on this hwy you speak of?
Modern psychology indicates that people who unnecessarily criticise others are often deeply unhappy. Such individuals may have low self esteem or perhaps may even be depressed. When people are sad or insecure, often the world becomes a very dark place and they see their enemy everywhere. It is at this time they start to 'act out'.Putting down others can also be considered a form of 'projection', in that the aggressor projects onto others what they really feel about themselves. When an insecure person calls someone a 'gimp', really this is a direct reflection of how this person feels about themselves. Accordingly, this person will insist on insulting the other first as a means of escaping these negative, insecure feelings. The more unkind they are, the more distance the aggressor then creates between the victim, resulting in the need to work harder to gain the victim's attention in future online situations. Much like the attention-seeking behaviour of a naughty little child, the aggressor will then try to re-establish this connection via inappropriate means, as highlighted in the above forum post.
thats gold jerry! gold!
why do you always have to be so negative?
coz that's how I roll.
also esp to sam cos he went out and bought a car everyone told him not to, and now have to watch and listen to slowly go about everything arse first. lets get real, it's only a matter of time before he gets dicked, then blacklisted, then targetted, and he comes on here and has a cry cos the cops are camping outside his house waiting to suspend his license and make him go through an EPA.
once he gets something in his head he never lets it go, he loves an R32, that's fine. why not buy a N/A? nah, he sees all the guys rollin in turbos like Kris and Hamish goin on about 11ty billion killabees at the wheels and wants to be part of that. these guys aren't on their P's and are a lot older than him. it's just plain thinking with the peen instead of the brain.
if we all sat around givin each other reacharounds about how awesome each others cars are, and JO each other silly about the faggotry you guys indulge in when it comes to modifications, then you'll end up with Kris never knowing that his car looks like a skittle coloured hovercraft, jeremy with sunken battleship chromies for wheels, niggaroj with enough clearance to hide Assange and Bin Laden under his wheel arches, mohsen with a dose pipe, etc.
no. I'm sorry if some of you delicate little flowers can't take creative criticism with a pinch of salt and not get butthurt over it. if you don't like it you can get the fuck out.
yup, totally got me figured out. so insecure. i cry myself to sleep everynight cos I'm so jelly about you guise.
  • Like 2
  • Nope 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
