show me the hundreds of people with 250Ks without doing anything to engine other than the usual 10K service :thumbsup:
Not really a fair comparison when you take into account the way jap cars are generally modified and treated compared to a luxury euro...
yeah, I like how those foggies fit into the vent tho, maybe pull the frosted plastic off and replace with clear perspex and a bright white/yellow LED array behind it? Would look tits. Would also set it apart from a sedan front?
The only thing is I would need to get something like that made up! Its already set apart from sedan front because it has different grille and bits under the foglights.
i just took my car out to the shops, ill eat my own words a few pages back and say i want more power!!!! pinch.gif
and wtf, i drove dads 740 last night and the thing was f**kin awesome, comfy as, nice sounding 8. just needs pipes
Edited by Mohsen
At least smash the orange reflector out. and chuck some of these indicators in:
embrace your inner leb
wow I knew you were full homo, but you actually cuddle while you're inside dudes?
ill buy your front bar, grill, bonnet and front seats
you also need his front guards, indicators, and bumper support genius.
lol...grant you going to buy another gtr? one for track and one for parts... lol..
You're cheeky!
Nah, just wondering how much he's selling, thats all.
Mohsen, I'm thinking of selling my pair of 32R seats (bought the seats off Andrew aka hoy32 before xmas), make me an offer if you're keen.
was bored and thinking bout jobs, so i decided to check out apprentice mechanic wages....
googled it and $7.05 p/h 1st year.... faaaaaaaaaark that! its the same as cheffing ffs! and that's BEFORE tax
Glad I work at Coles at $22.21 an hour forcing foods into shelves (my hours may be shit but if the money's in bank, can't complain).
But I need better career...
Thinking of enrol Counselling or Accounting courses but don't know what I want though.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
