full cockpit with fixed back seat and g27 went for $365 on ebay today, in Sydney and pickup only though otherwise I woulda grabbed it.
got a mate who is a metal fabricator, so he should be able to knock up a pretty good one for me...
when you ebay shit, dont bid until the last minute.... and when you do bid, make it a random ammount, not a whole dollar value...
say i'm bidding on an item that ends midnight thursday i will just watch it, and then at like 11:55 thursday i'll place a bid. if the max i wanna pay is say $200, i'll bid $222.22
Use JBidWatcher to bid at 11:59:50
why?
so if someone bids 222.00 they lose
yeh... cbf using sniper programs as i rarely use ebay...
i just bid last thing before i go to bed.... if i desperately wanted something i'd think about it i spose ;)
i give it 5 mins as i have lost once before when my net dropped out in the last minute :/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
