supra was just ghey. whats worse is you still see supras around here with the same side graphics :sick:
best part of that movie was the 355 revving at the lights
There's a F&F supra look a like that lives on apollo rd taylors lakes. Plates MATTZ or something.
Paint looks like its fading now.
that red 33 front bar is it a bar plus lower lip (the black) or just a gtr bar with bottom part painted black.
me rikey.
same as my front bar series 3.. Red part is one part, the bar itself, black part is a plastic what Nissan call 'air spoiler'.
They can be seperated as they're only held together with screws.
another NA 33 p-plater. Drove home next to one of those on saturday.. complete with horrific fibreglass front bar, terrible offset rims. Yamaha sticker across the back windscreen, shopping list down the guard.. and the piece de resistance - GT-R badge ebay copy!
Yer I'll pick sizes ;)
Have a look at enkei nt03, personally they look awesome!! Better quality + lighter at a slightly higher cost than rotors....
Oh and where you getting this car from, was there more imports? A friend of mine wants a 33 na manual...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
