Think there's a subtle difference in the skirts themselves as well, think it was something like more of a curve or indent in the actual skirt towards the middle, probably to accommodate for the difference at each end due to the guards...
I think I've seen people do it, but there was probably some work involved
F<------------------------------------------------------------------>R
166cm
26.5
approx
mmsed you 3 photos alex let me know if you get them, looking closely at it the guards do go out pretty wide which is why its in 2 pieces from the looks of things
Anyone who's after a sick electronic boost controller (Turbosmart e-boost street) should consider buying mine.
Only $350.
http://www.skylinesaustralia.com/forums/topic/352443-turbosmart-e-boost-street-ebc/
Selling due to sale of car : (
yeh you'd think it would be easy to find em in white but i cant, so yeh was just an idea IF they fitted from the pics leigh sent it seems do able but not worth the effort its only side skirts anyway.
if you'ze see some in any colour stock hit me up do want. asap.
I don't wanna pay $300+ for that seat because I know they were $200 each not long ago haha.
Thinking about maybe a Velo or OMP fixed back... Around the $500-600 mark. Thoughts?
velo GP90 in black
that's what i'm going when i CBF spending the $$$, and the bride seat in the link is exactly what I am running at the moment, it's decent and would be easy to resell if you want a mint seat later... rails will set you back like ~$100 secondhand from j-imports and he usually has them in stock. fwiw it sits a good inch lower than GTR seat on superlow rails
looks like a fish tank
buy it and you can do whatever you want with it
sitting low is where it's at...when i took my seats out and put stockies back in to sell, felt like SHIT. felt like sitting ON the car rather than in it, and it was surprisingly un nerving taking a corner at any kind of speed in the stock seat as opposed to in the low, supportive aftermarkets I had
sweet, black?
hamish & dez- oic
i was sliding all over the stock 32 seats when i was fanging it through corners.. lower driving position= reduced center of gravity = driver being stable at speed?
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
