better seat = more supportive. don't try to make it more complex than it is
reasonable explanation :P
sounds good, as long as it suits the other trim bits... hate seeing cars with red buckets and black everything else
problem is that the holes in the 33 are designed for a bottom mount seat and as such are too close to the middle. side mount requires them to be further apart.
basically i had some bride FG rails and was trying to put a side mount sparco seat in there and the seat was like 50mm wider than the space between the rails.
if you get desperate just run the stock seat i spose... or you could borrow mine for the day if you CBF getting them from micolour?
My rails were designed for Recaro SR3, by top mounted I mean the seats sit on top of the rails.
For you Billy, you can have both fOr $200, frOm memory, Thuy from J-Imports is selling $200ea
What car were they made to suit? Will they bolt straight up?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
