Stone grill eye fillet @ Paesanos Knox, don't question it, just do if you haven't already. I have these almost weekly, it's a terrible addiction. You cannot top the advantages of cooking it yourself (instantly) to perfection, having the actual meal come out in 15 minutes, and having a permanently hot meal. $30 for 250-300 gram eye fillet (varies on the day, but a good size and always good quality meat) including sauce and chips/salad. An extra $15 will get you another piece of meat (never done this, so don't know if it's the same size or not). I've been to most of the well known steak restaurants in Melbourne and the only ones that have come close IMO in terms of taste / overall quality are $50-60 for a piss small eye fillet not including sauce etc. Outback Jacks was decent but it had me wishing I hadn't ventured outside of my comfort zone.
You have to cook it yourself?
and 300g is a snack...
+1 dezz.
I think 300g is acceptable for lunch (coz I eat 7 meals a day) but if I've waited long enough for dinner, I'm gonna want a shitload more than that.
but you're tiny! have you grown from the last time i saw you?
eye fillet is always small though, unless you wanna pay big $
Went to this place in Richmond called Vlado's for a mate's birthday once...you pay $90 a head and you get like 4-5 courses I think
first is a home made sausage
then they bring out a plate of small pieces of different meats (eye fillet, pork and lamb I think) with bread etc...
then the main course you can either have the eye fillet, or the porterhouse...I got the eye fillet, and it was the biggest eye fillet I've ever eaten (apart from when I cut my own at home)... then dessert
When I go out for dinner/lunch I get a porterhouse 95% of the time, sometimes rib eye, sometimes rump (outback jack's rump steak was actually very nice)
usually try to get at least 400g or I feel like I need another meal..
checking out this Mrs Parma's joint tonight...
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
