The 33 I liked is in fact a 1996 (Compliance plate said '98, green plate pre-SEVS btw), should I steer away from it or not even though it isn't under finance or stolen or write-off register?
imo, if you like the car just get it every car will have small problems from the 90s mine needed new suspension and tyres as well as needing to repair the front lip but still loved the car when i saw it so i got it! :thumbsup:
tl;dr Shit can be fixed :D
Nah, that isn't what I meant, I were saying the car was complied as '98 model when the actual chassis is in fact a '96 model, not sure if I can live with it.
buy mine man.... 30k
Since you don't have the Professors on, no thanks.
Haven't had the chance to look at grey 33 in woop woop, may do that this weekend.
harden the fuck up princess. Was probably a typo in the CPA registry that sent out plates.
If the car has been registered, and has a history in one of the national registration systems, no one gives a shit about the plates. The only thing that's used for is the initial rego.
Grant come to shep on Saturday and tell the guy to meet you at DECA rolleyes.gif
Shep is closer for him.
Just got a message from the seller, he doesn't seem that keen but told him I'll be there...
Shan, is it pretty common with pre-SEVS cars?
Just want to be sure before I go stupid and buy it.
It's not common, but it's not surprising. a car I bought didn't even have a plate. which was fun, ran around for a month trying to get it from canberra and it turned out I didn't even need it to reg the car.
just make sure the VIN on the plate of the car matches the VIN on the manufacturer plate, and then run that VIN through FAST to make sure the specs of the car match up.
eg: 6U9000ECR33123456 = ECR33-123456 = RB25 R33 GTS25t
Thanks for that but, is error on import approval or mistake by Canberra put it on wrong year pretty common during pre-SEVS days?
The VIN on said 33 isn't 6U900xxxx it's 6T91 thingy hence my curiousity, what sparked it when I ran it thru Vicroads check and FAST (VR listed it as '98 whereas on FAST, it's 96).
6U900xxxx is new SEVS system, under CPA it was some weird shit.
Errors happen, check that the VIN numbers match up properly. No one gives a fuck about the year.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
