Not keen to sell his car then...oh well.
I do find this strange that you ring ppl about their cars and they couldn't give a f*k! pisses me off.
We get sick of timewasters. Hard to seperate genuine from timewaster.
seriously f**k my life f**k my luck f**k everything
buyer gets the banstick on ebay.. WTF flamin mongrel didnt even leave a number and we were supposed to meet up on thursday so i can get my cash and he can get the car! hope he gives me a call tomorrow.. not holding my breath though
If it makes you feel any better I got f*cked over too Mohsen.
fkn diggin 32s heaps lately, what happened to it?
what happened to what?
good ol' 32's. I need typeM skirts, roof spoiler, boot lip and moar lows. Need to fix up offset on the front too. Easy fix is spacers but ive had troubles with them in the past with constant vibrations
apparently his dads business account so its important to get no neg reps
Think you're thinking about Moshen...we're talkin bout the nice 34 GTR that only wen't to ~$40k
Dezz, even with 33gtr rims they look the business. Have to be lowww though
Yeah abu's looked good on 33GTR's and low...
that black one looks real nice, pretty much how I'd wanna do one, maybe different wheels but have to be good fitment..
Looks like some custom headlights on it too..
oh my bad, did the gtr sell for 40k? or nah?
pat - i mean did is it from melb that black 32, did it get sold etc?
oh nah owned by this guy
http://www.skylinesaustralia.com/forums/topic/119761-r32-pix-only/page__view__findpost__p__5716327
did the $500 less people not come back then ?
It would never have sold for '$500 cheaper' anyway, they were out to f*ck me over from the start.
Lesson learned, no going out of the way to help anyone from now on. I'm too f*cking soft.
You might live to regret that unless you sell it in the near future...The longer you keep it the more it'll depreciate, as well as any maintenance and rego expenses.
Sometimes it's better to bite the bullet and move on.
last worked yesterday, gave it a high pressure hose but not in the engine or anything .. oh had sway bars installed last night cant see that having an impact.
probably just knocked the cable going from the PTU to the coilpacks a bit. engine moves when under load, just enough to cause a break in signal.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
