anyone wanna come fishing tomorrow morning meet alvin and i out the front of audi in the city at 4:30 sharrrrpppp
if yall want my number its in my sale listing
and i unclipped the mechanical chin lip cables so im rockin it 24/7 lol
already scraped it while coming out of a carwash
wtf is a chin lip? You talking about the front spoiler?
Yeh that thing.
there is a reason why it goes back up, so you dont damage it when driving slow. It pops down at 80km/h, and works with the button when handbrake is up. Saved me many times, when the bar just makes it over the kerb. Any lip/spoiler would have been destroyed haha
