now when do you ever NEED to clear a curb?
Not saying you need to, just saying it makes life easier when you can clear if there is a kerb or concrete stopper when parking.
The front spoiler retracts allowing me to clear the kerb. When it is down, it would smack into it, but the clever japs made it pop back up under 60km/h
pretty simple.... stop BEFORE the concrete
Statement: daily drivin easier when can clear kerb.
Reference: If car can clear over kerb when parking, then it equals easier as one constraint of parking has been eliminated.
Result: statement is valid with reference
/End
What you are suggesting is not related to original statement and I am not disagreeing with what you are saying.
but that car looks tits
tits bro. tits
will do this if i keep her
and yes, i know the front wheel is a bit pixelated, Are you positively annoyed friend?
Edited by Mohsen
Mohsen i've got a 25de/20det manual box if you decide to keep/convert it :thumbsup:
remember my car is a GTS4 and im a broke ass student atm lol
will do manual conversion later
Nah, gave them to mate a while ago, sorry.
all good bro, found a set of pods from some place in adelaide
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
