im using the powerfc boost kit and it works well
when you use it you get boost print out on the hand controller and the powerfc will correct based on boost as well
set and forget and away you go
set target boost, set duty to reach that level and your done
it doesnt do dual solenoid or any fandangle stuff
so if your on std turbos etc its fine
if you want 3.6kgcm2 of boost with instant scramble then get a dual solenoid unit
Ok...
So a Power FC does a boost controller built in?
i wonder how your 34R would go with 4.11 diff gears
how do you find its acceleration at the moment with std diff gears scotty
well i dont have anything to really base it on but its definitely quick. for a 6 speed the gearings are very close together. i can be in 5th doing 60km/h and still have enough pick up to get to 100km/h quicker than alot of little cars. i find first gear to be very quick and 2nd gear is the fun gear because if im on fullboost in 3rd im going well over any speed limit.
that probably didnt answer your question lol. if you have any specific questions about it i can answer.
A question for wasteland, I have never changed the pannel filter in my gtr and was thinking about doing it this weekend, I have a sticker on the airbox saying nismo filter, I was wondering if there are any markings/branding on the filter itself to let me know that it is actually a nismo/k&n filter?
the powerfc has the logic and code built into the unit for the boost control kit
but you cant use it without the sensor, harness and solenoid
the menus are on the hand controller etc
the boost kit itself includes
an additional wiring harness
a map sensor
a boost solenoid
on the the side of the powerfc is a white socket, you plug the harness in there and plug in the map sensor and solenoid
so you dont have to do any wiring or splicing etc, just plug and pray
then set boost on the menu and duty and your done
the AVCR uses the same parts but has different controller logic
the avcr has boost scramble, boost gain etc and other features
but it uses the same sensor, harness, solenoid
you can mix and match them (the parts)
No. It's a seperate add on piece.
a map sensor
a boost solenoid
I see, cool thanks!
nah most agents drive bmws/lexus/merc/audi well the decent ones the average ones drive mazda's/honda's etc
i just need something suitable for towing and i dont see myself in a 4x4 could get a lexus gs430 4.3ltr v8 would probably do the job but not sold on teh look of em
i rkn ve's look tits.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
