im using the powerfc boost kit and it works well
when you use it you get boost print out on the hand controller and the powerfc will correct based on boost as well
set and forget and away you go
set target boost, set duty to reach that level and your done
it doesnt do dual solenoid or any fandangle stuff
so if your on std turbos etc its fine
if you want 3.6kgcm2 of boost with instant scramble then get a dual solenoid unit
Ok...
So a Power FC does a boost controller built in?
i wonder how your 34R would go with 4.11 diff gears
how do you find its acceleration at the moment with std diff gears scotty
well i dont have anything to really base it on but its definitely quick. for a 6 speed the gearings are very close together. i can be in 5th doing 60km/h and still have enough pick up to get to 100km/h quicker than alot of little cars. i find first gear to be very quick and 2nd gear is the fun gear because if im on fullboost in 3rd im going well over any speed limit.
that probably didnt answer your question lol. if you have any specific questions about it i can answer.
A question for wasteland, I have never changed the pannel filter in my gtr and was thinking about doing it this weekend, I have a sticker on the airbox saying nismo filter, I was wondering if there are any markings/branding on the filter itself to let me know that it is actually a nismo/k&n filter?
the powerfc has the logic and code built into the unit for the boost control kit
but you cant use it without the sensor, harness and solenoid
the menus are on the hand controller etc
the boost kit itself includes
an additional wiring harness
a map sensor
a boost solenoid
on the the side of the powerfc is a white socket, you plug the harness in there and plug in the map sensor and solenoid
so you dont have to do any wiring or splicing etc, just plug and pray
then set boost on the menu and duty and your done
the AVCR uses the same parts but has different controller logic
the avcr has boost scramble, boost gain etc and other features
but it uses the same sensor, harness, solenoid
you can mix and match them (the parts)
No. It's a seperate add on piece.
a map sensor
a boost solenoid
I see, cool thanks!
nah most agents drive bmws/lexus/merc/audi well the decent ones the average ones drive mazda's/honda's etc
i just need something suitable for towing and i dont see myself in a 4x4 could get a lexus gs430 4.3ltr v8 would probably do the job but not sold on teh look of em
i rkn ve's look tits.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
