Good luck Jez...the rest of the "pedo" crew are behind you :thumbsup:
And yes Moh...you've just experienced one of the supposedly rare situations that will never happen to people who drive turbo cars on their P plates...and your insurance company would have presumed your fault :)
Now stop driving the friggen thing and consider yourself lucky! Have had a kid ride his bike in front of my car before I slammed on the brakes...not cool. Dickhead didn't even acknowledge he'd done wrong, just kept riding.
not good pat.
yeh adam. have someone coming around on sunday to check it out, gave them a call and they didnt mind the front scuff so all good
was so weird. it was a main street .. i wasnt speeding or anything, just doing 50 and bam, future road kill jumps out of no where and i have no where to go, if i went left i would have rear ended a car, if i went straight i would have cleaned him up so it was right and hope for the best.
5th gear is on.... that idiot woman is testing the scuderia...
time for a channel change, not in the mood to hear her annoying screaming and giggling as soon as she goes over 60mph
I knew a guy that did that too. He got a massive amount of paid leave off work + counseling etc. but it actually didn't phase him lol
Double win.
(for the train driver) scrape doesn't look so bad in the day light..
my mate was a train driver and splattered some chick committing suicide.
Happens a lot! Very popular way to commit suicide.
Wouldn't phase me either, can't take responsibility for something like that. All that compensation sounds nice though :)
Exactly. I can understand how people might be shaken up by it, but personally I'd get over it in about 5 minutes.
If you were at fault and had the burden of it then yeah, the guilt would be insane. Otherwise it's just another suicide. That shit goes on every day.
I've seen people die, and yeah it's f*cked up.. but it doesn't linger on my conscience. I'm like wow for about 3 minutes and don't give it another thought.
EDIT: Removed personal shit coz it was too deep for wasteland.
Edited by jezza boii
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
