yeh its got a pod rofl
driving home my mates like man WTF is that noise!
also has calais tail lights with the light up middle garnish. it looks alright, see how i go with trying to sell this one, at least i can take my time
yes, finally. let the boat jokes begin!
i want a VZ monaro front now... >_< and sigz... and to slam its arse...
you can never take the habib out of an arab..
Edited by Mohsen
Yeah, grandparents, aunts uncles, cousins, friends... It's horrible.
The prez introduced changes because that's what the people wanted, and now home grown terrorists are f**king the place up.
(and some may think wtf why would I support a dictator, discrimination. 50 years ago my kind were the negros of the arab world. The current presidents father changed that)
:( pulled the fuel rail for the 3rd time in 2 weeks yesterday, had leak from around injector 2 so took the injectors to get re-co. came back no leaks all new seals so i re-installed ... it leaked again ... had my mechanic re-seat and reinstall incase i was a retard.... it worked for about a week ... then leaked again ... so now the injectors are out again.
I don't know whether to keep my car at my grandparents place for the next few years until I get back to Aus and the turn it into a trackcar, or just sell it now.
What to do, what to do... Suggestions?
VT SPac Attack? that's what my old man bought to drive around when the ceffy was in the shop. Drove it a month before I convinced him to go halves on a GS.
Cube it.
It's a fuckin car, not your first-born. Letting it sit depreciating is a totally homo move.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
