Exactly. I'm not out to impress all you guys unlike the rest of you sheep :P
But your car does give arabs boners. So you are impressing someone. Oh and they're not the saudi ones that drift lambos either.
When you have a decent crt that works you can talk :P. And I'm not talking about your boy loving queer golf that you want to have plad roof lining
all my cars work exactly the way I want em too.
problem?
Anyone tried one of these?
Pretty unique taste actually. I'm liking them as a chill-out drink. Just something to sip on at home. Probably down a few (or 6) tonight while I play COD for the first time in 2 months :P
You gonna be online tonight Kris? Now's your chance to woop my ass. I'm gonna fail so hard.
Tempted to buy those valve caps purely on account of the hard gay gif lol
used to smash the hard gay out back in the old wasteland....HOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
Might fire up some COD after the football..
Do you play PS3 dezz?
If so, feel free to add me: jezza_mr2
I'd completely embarrass myself though. 2 months without playing and I wasn't even good to start with :P
yeah PS3, dezzmang...add me coz I'll forget to add you.
what game mode are you gonna be playing?
2 meat pies and watching footy on tv. What is happening to me?
Hamish - setup looks neat, i'll be sure to have a peek and earbash on Sunday :thumbsup:
lol.. i wont be in my car tho... the new engine is still not in... should be a week away :/
i'll be indriving bombtrack's 34
you know how i know you are gay?
it's cause you drink top bloke drinks
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
