decent 2 hour 40 minute futsal session
right foot f**ked
guessing by tomorrow i wont be able to walk on it at all
work tomorrow should be fun...
in other news, bored.
Faark, that's a decent sesh. Not good. You still headed o/s in a few months?
Even better, tell him to do some good prices on the stuff for me.
Is that how you know Jess?
:laugh:
Was a joke man, not all Asians are related.
I know Jess through my friend who lives in Point Cook.
I believe she is jamies cousin.. Lol
:rofl:
oh i see, forklift driver forking her?
Jamie.. not helping asian stereotypes being related to *everyone* in melb lol :)
:rofl:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
