gt2 mmmm
hahah f**king good ownage! worth the watch
http://www.youtube.com/watch?v=N8fsgs49r8U&feature=player_embedded
Saw this a while ago. Epic ownage. If it was filmed in Australia, those guys in the truck would be from the northern suburbs.
