Clutch pedal squeaking like a bitch, how to fix?
Depends where squeaking is coming from. If footwell, spray some silicon near the top of the pedal arm and work it in by pushing the pedal.
If coming from outside the car, which is more common, spray some lithium grease on the clutch release fork/arm...the part of it inside the gearbox bellhousing, which rests against the pivot ball. You'll have to peel back or remove the rubber boot that the clutch arm travels through to get inside there.
i'll do that when i get my car back...
Cool thanks, too late to have a look now but it just started tonight. Wanted to make sure there wasn't any 'special' stuff apart from the usual... cheers
Oh and don't spray towards your clutch! Just focus on the pivot ball part and retaining clip, which is the cause of the squealing. It'll all make sense when you're looking at it.
off topic i found the best pho as well Ham
however you have to fly to vietnam lol
place called Pho 24 and it was awesome :D
lol i'm not surprised... :/
i work IN a pho joint now man, so i make my own ;)
Til his mummy makes him dessert. Thinking ahead. I like it.
For me, 12 hours til I eat something a bit more interesting :thumbsup:
seriously man, we dont need to hear about every chick you bone or think you are going to bone...
we've all had sex before (except mohsen)
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
