That guy has to be the ultimate troll. No way is that vid serious.
I'm not so sure..
Volt
Free
Anything goes
Volt entry is actually something ridiculous like $15...Should be free because it's a hole, but people do actually pay to go in there...
Not every thought in your head should be reproduced verbally/electronically etc
You ain't gonna get poon typing phaggotry like that
I like this guy. :cheers:
I appreciate it man, but I don't really need advice on "how to get poon" :thumbsup:
Also not too worried about what girls on here think of me :P
the ones who things up the most are usually in reality the exact opposite. :whistling:
its like theres pretend rich who brag an shit then there is real rich who dont say anything but you just know they wipe there ass with silk
wiping asses is for peasants.
Bidet and douchettes brah.
Shan where you been homo.
Also
fight fight fight!
Rimon v Jeremy
Why...
Kunts shoot down 11ty ducks and it's all good
Kunts stone a swan and it makes the front page of every paper
Racism towards the ducks.
Why?
I tend to agree with this. I just don't mention money coz I'm a poor kent :P
Anyway, I'm off to get my drink on with Birds and crew. Have a good night people!
Edited by jezza boii
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
