here around the west/north even tonight seen one had a red/black theme happening looked very nice.
S4 is a 4 door sedan you mean S3? yeah i love em it's the only hatchback i'd get both old and new hence why i was asking about your golf coz apparently they're very similar. the 1.8T ones anyway...
\S4 is a 4 door sedan you mean S3? yeah i love em it's the only hatchback i'd get both old and new hence why i was asking about your golf coz apparently they're very similar. the 1.8T ones anyway...
sorry, meant RS3, not S4. probably won't get it in oz, but an S3's still pretty sweet.
I'd take a basically stock 34gtr or 33gtr even over a modified gtt not to mention 34 Gtts look like ass ugliest of all skylines without serious styling changes
i want to go back to RWD i think. im actually checking out a E46 m3 tomorrow.
they making a RS3 too? would be epic tuff
now im thinking of getting a really nice and worked r34 gtt i still love skylines :(
you can't go from a GTR (any) to a GTT what's wrong with you..
Tough shape look so good with the concave csl wheels! But they are pricey & high kms I find
the one im looking at has the csl wheels on it. has 97,000km on it good thing is i dont have to worry about timing belts on these cars.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
