You're assuming they'll sag without having seen them out of a top/bra...Shay Laren has her well and truly covered for size, and I wouldn't say they're hanging at her knees..
That and the fact the rest of her is amazing, there's no point wasting time talking about some other chicks cans you haven't seen..
Google'd - they are fatty/flabby rubbish cans that would be like playing with a balloon filled with milk.
Soft and squishy.
Try again.
Soft and squishy.
Try again.
That's up there with Jizzy boy's post as most ridiculous...
If you actually believe what you just wrote, you're a muppet, plain and simple.
Ash.
I'm also a fan of the smaller/firmer but I wouldn't knock back that chick, that's for sure!
Well of course you are. The ratio of 15yo chicks with big cans vs small cans is firmly in the small cans favour
:laugh:
:laugh:
Incorrect.
Have you seen 15 year olds thesedays?!! The younger girls I've been with have had the biggest cans lol. Always firm though ;) Wouldn't wanna see them in 30 years..
Soft and squishy.
Try again.
Whats wrong with big tits?
So they might be a bit lower, but thats gravity!
Small girls with big cans ftw, you guys are forgetting about ass, can always play a big part.
On the boob topic, depends on the girl, some look hawt with hooters while some can get away with little tits, me personally. I like a decent sized set.
Bit early? :P I pretty much don't sleep lol.
I agree, in that pic it looks that way, but in the movie you'll see it's not the case :) She's also a bit flatter than that I think.
Birds, do you still have plans for tonight? Gathering at mine if you're keen (same goes to anyone else, except mohsen)
Forever alone.
All I'm going to do this long weekend is SLEEP.
Edited by Mohsen
Having a GF with the largest set of breasts I've had the pleasure of working with, I can say I'm amply qualified to have the final word on mamories of such magnitude.
1. They sit well naturally
2. No strech marks, yet...
3. I'm sure with age, there will be some issues
So the verdict, enjoy thenm young. Them lop them :D
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
