Went down to visit Trent to see how the cars going, ended up staying for about a hour and he was showing me how stuff works and showing me around the software which was very interesting (for me anyway) - a top bloke.
Almost burnt my face off with a huge flame on one run :D
Maths - boring!
I can't even work out simple maths these days.
Ditto. The only maths I use every day is division, multiplication, subtraction, addition and percentages. Everything else is irrelevant to my life. I had to do it up to year 12 to get into my uni course which I then dropped out of. Fml. I hated maths so much.
Only dropkicks get their girlfriends flowers in boxes.
Boxes are for friends who don't put out that you still want to keep a line of communication open with, and dead people.
Hmmm it isn't that serious Atm so something that isn't all like omfg I love you would be pretty nice.
provide it
can't find shit on google
It's canned tuna in oil. Any nutrition table from a similar product will provide similar numbers
It's in 100% olive oil though...So is Safeway 'select' brand...Most others use a blend of oils..
My uncle buys so much Sole Mare tuna that he now deals directly with the company instead of buying from Safeway. I thought it must be good and went out and bought 10 cans. Couldn't stomach it for some reason :( John West is what I eat each day now.
the best, with soy sauce and wasabi :D
sirena is what i like the best in oil
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
