Willing to bet the guy went on a last minute thrash n burn before selling the car to you...makes me wonder how many people actually do that and f**k the car.
He said he went for a last drive and it "randomly" spun out and hit a pole. yeah and i'm santa clause...
9-9:30 is a sleep in when u wake up at 4:30am weekdays. Gotta be at the ground in 95 minutes.
Unlucky rimon
Were you playing at Jacana?
that sucks mate but im sure you will find another one.
For those sort of K's and price I doubt it. Will take a while...
VT IS SOLD MOTHERf**kERS
Congrats, sold quick...
Make sure you don't make the mistake again of getting a skyline that you don't want ;)
Hi 5 to being temporarily loaded
400 isn't too bad. Looks way better than a cannon. But yours are so long lol
Yeh way to long gonna cut em for sure with stock rear bar will be a metre out and just look ridiculous
Ya win? Lost by 12 in the last 5 minutes. Only motivation for trying to get into 1sts would be so I can play arvo games lol. But then the midweek training would piss me off.
Nope lost by 5-6 goals but I only played first half. Right at the end of the 2nd was running back covering someone else's man, laid a bump on their massive full forward (read:120+kg) and he landed on my leg. f**ked my ankle and twisted my knee at the same time.
Strapped it up, played a few minutes of the 3rd and now limping around f**ked lol
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
