If you're talking about covering your own car, that should be covered Australia wide by the motor vehicle policy. If you're talking about covering a hire car, then travel policies can have a hire car excess waiver to cover some or all of the excess if you have a crash.
what about the other stuff, robberies and shit. lol, falling ill, getting hit by a truck, i dont know. the crap that can happen. someone breaks into the room and steals all my stuff.
How close does your phone have to be? My wall charger can only reach within 3 metres of my bed. Close enough?
Give it a try and see what happens. I normally have the phone charging on my bedside table and it works a treat.
Yeah that's all availble in travel insurance. Medical is a biggy.
Some may and some may not. You'd need to read the PDS for exact details. I know that CGU, who I work for, covers unlimited cancellations on some and up to $12k on your luggage documents, whether they are damaged or stolen. There's heaps of other stuff included as well.
i'll pm you a little closer to the date.
And at mohsen, you jizz on them
i assume they still wind back the clocks on evo 8's too? im looking at one at top secret imports but ive heard nothing but good things from these guys.
yeh can be, but the interior will tell u if km's are genuine
as well as general wear and tear on bushes etc
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
